Harley Vee Rubber 180/50R X 18 Whitewall Tire - Vee Rubber 16-4987
SKU 46-0451
$299.99
2999 ENTRIES 🎟️
$299.99 - $299.99
$299.99
2999 ENTRIES 🎟️
Tubeless Vee Rubber VRM 302 rear tire features all weather tread pattern for improved wet and dry road grip. H-rated construction and heavy duty sidewall for superior weight carrying capacity for larger displacement motorcycles. **WARNING: Newly fitted tires should not be subjected to sudden acceleration hard cornering or maximum power or braking for at least 100 dry miles. Loss of control and serious injury or death may be a result in doing so. By waiting till the 100 mile break in the driver will become accustomed to the feel of the new tires or tire combination. You should check and adjust inflation pressure to recommended levels after tires cool for at least 3 hours following run in. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. Universal fit for most Harley applications.
Vee Rubber #: 16-4987
0 Rear
