Harley Big Twin V-Twin Primary Cover Gasket Repair Kit - Gary Bang 76127
SKU 15-0621
599 ENTRIES 🎟️
$59.99 - $59.99
599 ENTRIES 🎟️
Repair your inner primary primary chain clutch hub clutch or left side transmission with our primary cover gasket kit. Kit includes nylon pad for primary chain clutch hub key clutch hub nut seal 4-speed inner primary seal shifter shaft oil seal inner primary o-ring derby cover gasket starter hole gasket 1/32 inch primary cover gasket inspection plate gasket solenoid mount gasket transmission drive sprocket lock tab primary chain adjuster lock tab clutch hub nut lock tab oil deflector plate gasket. Fits 1965-1982 Harley Panhead and Shovelhead models.
Gary Bang #: 76127
1965-1982 FL
1971-1982 FX
