Harley Sportster V-Fire Morse Magneto Coil - Volt Tech 10-2015 - OEM 29524-55A - Ironhead 1958-1969
This magneto coil fits Fairbanks Morse and most aftermarket units. Coil is 12 volt and has high output. *NOTE: Check that the magneto coil contact springs are on the output terminals before installing the magneto cap. **NOTE: Check the coil primary resistance requirements from the manufacturers of the ignition being used. Fits 1958-1969 Harley Sportster models.
Volt Tech #: 10-2015 · OEM #: 29524-55A
MOQ20
- Length: 2-3/4 inches
- Width: 2-5/8 inches
- Height: 2 inches
- Suggested to use with Magneto Coil Contact Springs.
| 1958-1969 | XLCH |
