Harley Big Twin V-Fire Distributor Top - V-Twin 32-1428
V-Fire distributor top features a one piece design assembled with genuine points and condensor set. Outfitted with one piece automotive points for ease of adjustment. Distributor top is zinc plated and machined with counter sunk hole. Can be adapted to distributor bases on all models as listed. Condenser is placed under this top mounts on underside on existing mount stud. Base and gear not included. *NOTE: Requires 3 pieces of OEM #2626 Round Head Screws 8-32 inch x 1/4 inch long. Does not include hardware points or top cover end clip. *NOTE: For use with late 1970-1978 one piece type point sets. Retro distributor base includes insulator post installed. The one piece point set has a jumper wire to connect to the post on the underside of the condenser which is mounted by a single threaded 8-32 x 1/4 inch phillips head screw its wire connects to the insulator stud. The lead wire from the coil connects to the insulated stud on the underside of the base. For Bendix-Keihin and Linkert carburetors. Fits 1948-1987 Harley Big Twin, FX (Super Glide), Flathead, Panhead, and Shovelhead models.
- Suggested to use with Blue Streak Ignition Point Set.
- Suggested to use with Sifton Distributor Top Kit
| 1948-1987 | FL |
| 1971-1987 | FX |
| 1948-1960 | G |
| 1948-1952 | W |
