Harley USB Engine Management System - Dyno Jet 1020-0843 - Twin Cam Dyna 2006-2017
SKU 32-3011
$349.99
3499 ENTRIES 🎟️
$349.99 - $349.99
$349.99
3499 ENTRIES 🎟️
Power Commander III engine management system is for fuel injected models and allows for both fuel and ignition adjustments. USB cable and 9 volt batery power adapter are included. The Power Commander includes an IBM compatible link cable and software package which allows you to fully map the fuel ignition curves on an IBM compatible computer. If a computer is not available the fuel curves can be adjusted by using three touch buttons on the face plate. This unit includes a specific map designed to improve performance over stock. Includes oxygen eliminators. *NOTE: Not for sale in California. Fits 2006-2017 Harley Dyna models.
Dyno Jet #: 1020-0843
2006-2017 FXD
