Harley USB Engine Management System - Dyno Jet 1020-0290 - Sportster 2007-2008
Power Commander III engine management system is for fuel injected models and allows for both fuel and ignition adjustments. USB cable and 9 volt battery power adapter are included. The Power Commander includes an IBM compatible link cable and software package which allows you to fully map the fuel ignition curves on an IBM compatible computer. If a computer is not available the fuel curves can be adjusted by using three touch buttons on the face plate. This unit includes a specific map designed to improve performance over stock. Fits 2007-2008 Harley Sportster models.
Dyno Jet #: 1020-0290
| 2007-2008 | XL |
