Harley Universal Black 8mm Pro Spark Plug Kit - Sumax 76081
Universal pro spark plug wire kit features 24 inch wire leads with 90° molded plug boots and straight coil boots with brass terminals. Wires have Spiro-Pro design that has 10 times the firepower of carbon core wires and heat protection to 600°F. Wire set works with electronic or points style ignition. All wires have a resistance factor of 350 ohm/ft and can be cut to required length. Great for magnetos. distributors or dual plug heads. *NOTE: If using an aftermarket ignition please check with the manufacturers OHM requirement. *NOTE: Not for use on 1999-up Big Twin and 2007-up XL models. Universal fit for most Harley applications.
Sumax #: 76081
