Harley Universal Black 7mm Spark Plug Wire Kit - Volt Tech 40157
Universal spark plug wire kit is 38 inch long with double 90° spark boots and is black carbonite suppression type. Spark plug wire kit is black 7mm suppression core type. Simply cut the wire to the desired lengths and install the supplied coil terminal clips and rubber boots. *NOTE: Not for use on 1999-up Big Twin and 2007-up XL models. Universal fit for most Harley applications.
Volt Tech #: 40157
- Length: 38 inches
