Ultima Oil Pump Assembly Polished - Ultima 98-518 - Evolution 1984-1991
by Ultima
SKU 12-8518
$319.99
$319.99 - $319.99
$319.99
Ultima #: 98-518
Ultima high output volume oil pump has a polished finish and performs with greater potential for pressures and volume. Includes gaskets oil/drain plug snap ring shaft key and screws with washers.
The H.O pump will feed at the bottom end at idle speeds keeping consistant flow throught the RPM range to keep from floating bottom end bearings.
1986-1991 FLST
1984-1991 FLT
1991 FXD
1984-1991 FXR
1984-1991 FXST
