Ultima Oil Pump Assembly Polished - Ultima 98-517 - Big Twin 1992-1999
Ultima #: 98-517
Ultima high output volume oil pump has a polished finish and performs with greater potential for pressures and volume. Includes gaskets oil/drain plug snap ring shaft key and screws with washers.
The H.O pump will feed at the bottom end at idle speeds keeping consistantflow throught the RPM range to keep from floating bottom end bearings.
| 1992-1999 | FLST |
| 1992-1999 | FLT |
| 1992-1999 | FXD |
| 1992-1994 | FXR |
| 1992-1999 | FXST |
