Harley Big Twin & Sportster Twin Tec Internal Ignition Kit - Daytona Twin Tech 3005-EX
SKU 32-3054
$469.99
4699 ENTRIES 🎟️
$469.99 - $469.99
$469.99
4699 ENTRIES 🎟️
Twin Tec internal ignition has a billet aluminum housing with wide timing advance adjustment range which accommodates stock to highly modified engines. With this ignition you are able to select single or dual fire mode and multi spark mode for quick starting and a smooth cruise. RPM limit can be set digitally at 100 RPM steps and has coil outputs to protect against short circuits. This ignition is intended for electric start applications and includes ignition coil and wire set. *NOTE: ARB compliant E.O. No. D-641. Fits 1970-2003 Harley Big Twin, Dyna, FX (Super Glide), FXR, Softail, Sportster, Touring, and Shovelhead models.
Daytona Twin Tech #: 3005-EX
1970-1984 FL
1986-1999 FLST
1970-1999 FLT
1970-1984 FX
1991-1999 FXD
1982-1994 FXR
1984-1999 FXST
1971-2003 XL
