Harley Twin Fire Ignition Coil for Dual Spark Plug - Dyna Tek DC6-4
SKU 32-9264
$209.99
2099 ENTRIES 🎟️
$209.99 - $209.99
$209.99
2099 ENTRIES 🎟️
Dyna Twin Fire ignition coil is designed to work with Dyna 2000 H-DI ignition modules. Twin fire coils are slightly larger than stock coils and fit with the stock mounting bracket. Twin fire coils can be used with any electric advance ignition system that incorporates dwell control except Dyna DS6-2 or similar type ignitions. Twin fire coils feature four output towers and fit dual spark plugs 3 ohms replaces Dyna DC6-4. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Universal fit for most Harley applications.
Dyna Tek #: DC6-4
0 Special
