Harley Big Twin Tuck and Roll Frame Mount Solo Seat Set - V-Twin 47-1654
Frame mount vinyl tuck and roll style solo seat set is black naugahyde on a steel base plate for direct frame moutning. The mount screw inserts are 5/16 x 18 thread. This solo seat mounts directly to the frame without springs. The front nose hooks clip directly into the frame and rear bolts to the side of the frame in front of the shock mounts on both sides. *NOTE: To fit 1958-1964 kick start lower frames the installer will have to extend the tabs. CAUTION: Dropping of this product may cause a break in the cover material and void warranty. Fits 1958-1984 Harley Big Twin, FX (Super Glide), Panhead, and Shovelhead models.
- Length: 16-3/4 inches
- Width: 11 inches
| 1958-1984 | FL |
| 1971-1984 | FX |
