Transmission Main Drive Bearing - V-Twin 12-0349 - OEM 8906
SKU 12-0349
OEM #: 8906
Mainshaft 4 speed needle bearing has an outer diameter of 1.998 inch. This bearing is precision ground to fit a later race.
Bearing has a width of.61 inch x 1.638 inch inner diameter. Outer diameter is precision ground for exact fit which results in the higher cost.
| 1982-1984 | FL |
| 1982-1984 | FX |
