Tourist Trophy Gas Tank Set - Wyatt Gatling 63719
SKU 38-0531
$299.99
2999 ENTRIES 🎟️
$299.99 - $299.99
$299.99
2999 ENTRIES 🎟️
Wyatt Gatling #: 63719
Tourist Trophy split style gas tank set features a 2.8 gallon capacity without the dash cutout constructed of steel in a raw metal finish. Rear bracket must be fabricated by installer not included.
For use with bayonet type gas caps. Top is smooth type without dash base cutout. Use for either 2 side of gas or 1 side oil on the right. The right side has two front 3/8 inch NPT and one 1/8 inch NPT male fittings for use as an oil tank. The left side accepts metric nut type petcock. Front mounts included. Order hardware separately fittings and plugs not included. *NOTE: inchTT inch stands for Tourist Trophy an early dirt track circuit. *NOTE: Top mount tab set mounts to frame with bolt. Loose tank can be lowered by modefying front lower mount set.
  • Length: 19 inches
  • Front Height: 9 inches
  • Rear Height: 2 inches
  • Front Width: 10 inches
  • Rear Width: 5 inches
1936-1952 EL
1941-1984 FL
1970-1984 FX
