Top Hat Style Valve Stem Seal - Kibblewhite 71030-4 - OEM 18094-02A
Kibblewhite #: 71030-4 · OEM #: 18094-02A
Top hat style valve stem seals come as a set of 4. Seals are for 7mm valve stems.
Seals are designed for superior oil control by using high temperature viton that is resists the effects of wear from gasoline oil and by products of combustion. Seals feature a taller than stock steel portion that provides greater stability to the anca of the seal that must control oil.
| 2005-2017 | FLST |
| 2005-2016 | FLT |
| 2005-2017 | FXD |
| 2005-2017 | FXST |
| 2004-UP | XL |
