Thor Rear Hub Assembly - V-Twin 49-5511
Thor rear hub assembly with nickel plated finish made by Michael Lange Company.
Assembly features 18 spoke holes on each end. The THOR Company has made hubs for many different motorcycle brands. Harley-Davidson mainly used THOR Hubs whereas other brands like Musselman Eclipse New Departure and Corbin were available upon request. There is nothing on the left side of the hub so it may be used on both belt and chain drive models. To use this hub on a 1911 belt drive single or twin would require a THOR coaster brake rear hub and a belt pulley attached to the wheel rim. *NOTE: Must order left side rear sprocket separately.
- Body Width: 6-1/4 inches
- Nut to Nut Width: 6-3/4 inches
| 0 | All |
