Stretch Chopper 3.8 Gallon Gas Tank - V-Twin 38-0279
New Old Stock inch Gas tank has a left side petcock opening and a fuel capacity of 3.8 gallons. It features ISO mount straps and a curved underside with recessed mount holes.
Center to center measurement of mounting holes are 13-1/4 inch. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check the petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock. *NOTE: Over 20 years old stock some rust and small dings on surface. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Top Length: 27.5 inches
- Bottom Length: 24.5 inches
- Rear Width: 2.5 inches
- Front Width: 12 inches
- Rear Height: 2 inches
- Front Height: 10-3/4 inches
- Front Tunnel Height: 6-7/8 inches
- Rear Tunnel Height: 1 inches
- Tunnel Length: 24-3/4 inches
- Tunnel Width: 2-3/8 inches
- Suggested to use with Smooth Style Gas Cap Vented.
- Suggested to use with Petcock Wing Type Chrome.
