Stretch Chopper 3.0 Gallon Gas Tank - V-Twin 38-0272
SKU 38-0272
$239.99
$239.99 - $239.99
$239.99
Gas tank accepts a left side 3/8 inch National Pipe Thread petcock and has a fuel capacity of 3.0 gallons. It features a curved underside and dual strap mount kit with bushings.
Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock.
  • Top Length: 23 inches
  • Bottom Length: 19 inches
  • Rear Width: 3 inches
  • Front Width: 9 inches
  • Rear Height: 1 inches
  • Front Height: 9 inches
  • Front Tunnel Height: 4-1/4 inches
  • Rear Tunnel Height: 7/8 inches
  • Tunnel Length: 22-1/2 inches
  • Tunner Width: 2-3/8 inches
  • Suggested to use with Smooth Style Gas Cap Vented
  • Suggested to use with Kreem Gas Tank Combo Kit.
