Stock Bore Engine Crankcase Set - S&S Cycle 31-0005 - Evolution 1992-1998
S&S Cycle #: 31-0005
Crankcase set for V2 type engines comes ready to assemble.
S&S crankcase set includes Timken left side bearing race assembly seal seal spacer oil pump drive bushing needle bearing pinion race for right side is pressed in and line honed ready to assemble. Also included are cylinder studs nickel plated case bolts crankcase fittings and a timing and magnetic drain plug. Engine case features stock bore and will accept flywheels up to 8-1/2 inch diameter. Manufacturer's Statement of Origin is supplied. *NOTE: Flywheel accepts early model crank pin. The rod set can be fitted with an early pin if required for installation.
- Suggested to use with Oil Pump Assembly.
- Suggested to use with Connecting Rod Assembly H-Beam.
| 1992-1998 | FLST |
| 1992-1998 | FLT |
| 1992-1998 | FXD |
| 1992-1994 | FXR |
| 1992-1998 | FXST |
