Stock 5.1 Gallon Gas Tank - V-Twin 38-0549 - OEM 61593-10 - Twin Cam Dyna 2010-2010
OEM #: 61593-10
Stock replacement one piece gas tank with a center fill panel opening is for EFI models.
Check the tank for flaws and fit before painting. The tank requires sanding and primer. Do not grind or sand the seams or joints. The fuel line fitting should be masked or plugged during painting for easy installation of the fuel line. Clean the inside of the tank. It is suggested to pressure test the gas tank and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Suggested to use with Kreem Gas Tank Combo Kit.
| 2010 | FXD |
