Starter Drive Pinion Gear 9 Tooth - Volt Tech 32-9201 - Big Twin 1998-2006
by Volt Tech
SKU 32-9201
$54.99
$54.99
$54.99
$54.99
$54.99
$54.99
Volt Tech #: 32-9201
MOQ150
Starter pinion gear 9 tooth for use with 66 tooth ring gear.
This ratio allows more PRM for easier starting and the heavier teeth configuration is less susceptible to wear by converting the 102 tooth ring gear to 66 tooth.
| 1998-2006 | FLST |
| 1998-2006 | FLT |
| 1998-2005 | FXD |
| 1998-2006 | FXST |
