Harley Spun Rear Fender Raw Steel 6 Wide - V-Twin 50-1349
Raw rear fender, a direct replacement for a dented, rusted, or missing stock fender. Universal fit for most Harley fender applications.
6 inch wide spun rear fender is rolled of 15 gauge steel with a raw finish.
Clearance for bracket and mount bolts. Great fit for 500 x 16 inch vintage full profile tires such as Avon Mark II types. Fender may require trimming and finishing for chain relief. We suggest pre fitting the fender prior to painting. Fenders have tooling marks on the rolled or beaded ends from the manufacturing process. Preparation is required before priming and painting after fender is test fit for ease of installation. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Length Tip-to-Tip: 27-1/4 inches
