Harley Big Twin Spring Fork LED 6 Volt Headlamp Insert - V-Twin 33-1668
SKU 33-1668
$109.99
1099 ENTRIES 🎟️
$109.99 - $109.99
$109.99
1099 ENTRIES 🎟️
6 volt LED Spring Fork lamp insert is for use with the original Cycle Ray and replica V-Twin headlamps. Insert fits 6-1/2 inch stock Spring Fork headlamps. *NOTE: LED lamp has H-4 base to accept 3 prong lamp socket. Installer must connect 3 terminal block wires to original wiring. 12 LED bulbs are available separately. The original lens can also be re-used or replaced with a glass lens also available separately. Fits 1937-1952 Harley Knucklehead and Panhead models.
1937-1952 EL
1941-1948 FL
