Spring Fork Front Brake Anchor Stud Kit - V-Twin 49-1742
Spring fork front brake anchor stud kit includes raw steel stud and parkerized adjuster screw.
Brake cable anchor stud for front backing plate was used until 1940 on Knucklehead VL UL RL and WL 45s. You can also use this stud to make a 1941 and up backing plate into an early style backing plate. Must be peened over or welded into place after installation.
| 1936-1940 | EL |
| 1936-1940 | UL |
