Speedometer with 2:1 Ratio and White Needle - V-Twin 39-0855
Replica speedometer has a ratio of 2:1 and features a narrow black rim numbers reading mph with a domed glass face. A knurled reset knob is included.
Includes a male speedometer fitting to accept cable. Accepts plug in lamp socket not included. The face features the accurate color for the years listed. The numeral graphics are silk screened on glass as original. *NOTE: Must order cable and mount kit separately. *NOTE: Accurate face design needle and colors for years noted although it fits any 2:1 ratio application. *NOTE: Use with 10 or 11 tooth speedometer drive gear with the appropriate spiral gear for cluster gear. *NOTE: Small quantity available from musuem projects. The speedometer face is accurate for the years it replaces.
- Suggested to use with Black Speedometer Cable.
- Suggested to use with 35inch Cadmium Speedometer Cable which has a male fitting for the speedometer head and a nut for the transmission drive.
| 1936-1940 | EL |
| 1941-1961 | FL |
| 1937-1961 | G |
| 1937-1952 | WL |
| 1940-1944 | WLA |
