Speedometer with 2:1 Ratio and Army Graphics - V-Twin 39-0298
SKU 39-0298
$119.99
$119.99 - $119.99
$119.99
Replica speedometer has a ratio of 2:1 and features a narrow black rim numbers reading mph with a domed glass face.
Includes a male speedometer fitting to accept cable. Accepts plug in lamp socket and reset knob not included. The face features the accurate color for the years listed. The numeral graphics are silk screened on glass as original. *NOTE: Must order cable reset knob and mount kit separately. *NOTE: Use with 10 or 11 tooth speedometer drive gear with the appropriate spiral gear for cluster gear. *NOTE: Small quantity available from musuem projects. The speedometer face is an accurate reproductions for the years it replaces.
  • Outer Diameter: 4-3/4 inches
  • Suggested to use with Black Speedometer Cable
  • Suggested to use with 35inch Cadmium Speedometer Cable which has a male fitting for the speedometer head and a nut for the transmission drive.
  • Suggested to use with Knurled Reset Knob.
1936-1940 EL
1941-1961 FL
1937-1961 G
1937-1952 WL
