Speedometer Drive Gear 7 Tooth - V-Twin 17-0094 - OEM 35635-69
SKU 17-0094
OEM #: 35635-69
7 tooth speedometer drive gear.
For use with 23 tooth speedometer drive unit. *NOTE: 66.5mm outer diameter for case clearance and fit.
- Outer Diameter: 66.50mm
- Inner Diameter: 55.58mm
- Thickness:.315 inches
- Suggested to use with 23 Tooth Speedometer Drive Unit.
| 1969-1980 | FL |
| 1969-1980 | FLH |
