Speedometer and Tachometer Adapter Ring Zinc - V-Twin 39-0034
SKU 39-0034
Speedometer and tachometer adapter ring is zinc plated. Adapter ring allows 85mm GPS speedometers and 85mm tachometers to fit FL dash panels.
Gps speedometer have nylon 85mm nut to clamp to dash panel. Use the V-twin adapter ring required for specific dash panel. *NOTE: Order speedometer adapter ring kit for dash type separately.
  • Gauge: 16
  • Inner Diameter: 85mm
  • Outer Diameter: 3.94 inches
0 All
