Spectro Heavy Duty DOT 5 Silicone Brake Fluid - Spectro Oils 310233
SKU 41-0194
349 ENTRIES 🎟️
349 ENTRIES 🎟️
Spectro Oils #: 310233
Spectro heavy duty golden blend DOT 5 silicone brake fluid comes in a 12 ounce bottle.
Designed to surpass all DOT 5 specifications and requirements. Heavy duty DOT 5 is the ideal brake fluid for all Twins specifying a DOT 5 fluid but its better because this fluid beats spec in every way. Meets full OEM requirements and should be used according to the manufacturer's instructions. This fluid is non-hygroscopic and will not absorb water or harm painted surfaces. Specially formulated for all applications. **NOTE: Do not use when DOT 5.1 or DOT 4 fluid is specified.
0 All
