Harley Big Twin Solid State 6 Volt Relay with Chrome Cover - Volt Tech 77378
Solid state relay is 6 volt three terminal style with a chrome cover with eliminator. It replaces original style mechanical relay for 6 volt 32-E style generators. Solid state relay elminator is housed in a Delco style body and base. The unit will replace stock relay on 6 volt 32-E model applications and will retain original look. Unit does not allow for use of the charge indication lamp on the dash. Mounts as original relay hardware is not included. Solid State relay is shipped loose with base and cover. Installation instructions (PDF). Fits 1936-1957 Harley Flathead, Knucklehead, and Panhead models.
Volt Tech #: 77378
- Suggested to use with Solid State 6V Relay Eliminator.
| 1936-1952 | EL |
| 1941-1957 | FL |
| 1936-1957 | G |
| 1936-1952 | W |
