SMC Electric Start Oil Tank Chrome - V-Twin 40-0648
SKU 40-0648
$329.99
$329.99 - $329.99
$329.99
Swingarm York oil tank features a chrome finish. Oil tank is for use on 4-speed models with a stock swingarm frame.
tncludes screw in filler cap with dipstick. Tank is for use on 1965-1985 models. York oil tank allows fitting of electric start motor kit. Tank does not have provision for 1968-84 clutch cable adjuster. *NOTE: Rear of tank mounts to frame tube. Raise tank as desired. *NOTE: Removeable bracket allows use on 1958-1964 FX and 1965-1984 FL electric start models. *NOTE: Order oil tank mount bracket set separately to mount to 1958-1984 FL swingarm frames that use electric start. Brackets can be modified to fit rigid frames. Filler cap features a original threaded style included. *NOTE: Tank shape referred to as inchHorseshoe inch or wrap around. Will NOT accept 1979-84 rotary top 4 speed transmissions type. SMC our original oil tank maker since 1979! Installer must fabricate mounting brackets for the front and rear of oil tank. Mounts not included order base plate separately. Rear bracket may need spacers to adjust height. *NOTE: Order 1965-84 mount base plate 1958-64 front oil tank bracket and 1941-57 mount base as noted or fabricate by builder.
  • Suggested to use with Front Oil Tank Mount Black for 1958-1964 models.
  • Suggested to use with Front Oil Tank Mount Black for 1965-1984 models.
  • Suggested to use with Oil Tank Mount Bracket Set
  • Suggested to use with Front Oil Tank Bracket
1958-1964 FL
1971-1985 FX
