SMC Electric Start Oil Tank Black - V-Twin 40-0641
Swingarm York oil tank features a black finish. Oil tank is for use on 4 speed models with a stock swingarm frame. Includes rubber bung type plug.
Includes screw in filler cap with dipstick. Tank is for use on 1965-1985 models. York oil tank allows fitting of electric start motor kit. Mounts available separately. Tank does not have provision for 1968-84 clutch cable adjuster. *NOTE: Rear of tank mounts to frame tube. Raise tank as desired. *NOTE: Removeable bracket allows use on 1958-1964 FX and 1965-1984 FL electric start models. *NOTE: Will not accept 1979-84 rotary top 4 speed transmission type. SMC our original oil tank maker since 1979! Installer must fabricate mounting brackets for the front adn rear of oil tank. Mounts not included order base plate separately. Rear bracket may need spacers to adjust height. *NOTE: Order 1965-84 mount base plate 1958-64 front oil tank bracket and 1941-57 mount base as noted or fabricate by builder.
- Battery Tray Length: 5-7/8 inches
- Battery Tray Width: 5 inches
- Battery Tray Height: 4-3/8 inches
- Suggested to use with Oil Tank Mount Bracket Set.
- Suggested to use with Front Oil Tank Bracket
- Suggested to use with Oil Tank Mount Base
- Suggested to use with Oil Tank Mount Base Plate Black
| 1958-1964 | FL |
| 1971-1985 | FX |
