Harley Big Twin & Sportster Single/Dual Fire 12 Volt Accel Distributor - Accel A577 - Sportster 1930-1973
Accel 12 volt electronic type advance distributor features the option of running either single or dual fire mode when matched with the appropriate coil. Distributor also features revolution limiting and a LED for easy static timing. This is designed to work with or without VOES input. The machined aluminum housing offers exceptional heat sink capabilites that can still be installed without disassembling the engine if stock heads and barrels are used. Installation instructions (PDF). Fits 1930-1973 Harley K Model, Sportster, and Flathead models.
Accel #: A577
| 1936-1973 | G |
| 1952-1956 | K |
| 1936-1947 | UL |
| 1930-1952 | WL |
| 1952-1970 | XL |
