Sifton Engine Pinion Shaft - V-Twin 10-0488 - OEM 24006-58
by Sifton
$79.99
$79.99
$79.99
639 ENTRIES 🎟️
$79.99
$79.99
$79.99
639 ENTRIES 🎟️
OEM #: 24006-58
Machined and hardened to factory specifications.
*NOTE: Must order case race key oil pump gear and key pinion gear separately.
- Suggested to use with Sifton Standard Case Race Left Side.
- Suggested to use with Motor Sprocket Shaft Key.
- Suggested to use with Pinion Gear Shaft Key.
| 1958-1972 | FL |
| 1971-1972 | FX |
