Harley Flathead Side Valve Linkert Carburetor Bean Pot Bowl - V-Twin 35-0281
Carburetor float bowl part, a direct replacement for a cracked, stripped, or leaking stock bowl component. Fits 1936-1957 Harley Flathead models.
Linkert carburetor bean pot bowl with early style hex cap features a natural aluminum finish. Bean pot bowl shape allows additional fuel giving access for long open throttle sessions.
Larger inner diameter adds 1.45 cubic inches to hold additional fuel. Extra capacity for racing applications. Has 9/16 x 20 hex plug at needle valve opening. Fits all brass linkert carburetors for additional fuel capacity! **NOTE: Original inchBean Pot inch linkert bowl design was developed by Tom Sifton of Sifton Motorcycle Products. As original float brass top cap is for use on Side Valve models only. For the float arm installation the center of the float arm should have.003 inch of clearance in order for the arm and needle to move freely.
- Kit includes all components but must be assembled and set to factory specifications.
| 1936-1957 | G |
| 1937-1948 | UL |
| 1936-1952 | W |
