Side Valve Feed Pump Upgrade - V-Twin 49-0094 - OEM 687-41
OEM #: 687-41
Feed pump upgrade for Side Valve models. Includes a rotor 4 scrapers and 4 springs.
Includes rotor with quad vanes for added oil pressure! Installation will require using multiple gaskets. Each rotor will require the back surface to be sanded down to each specific motor. NOTE: For the early model tall feed pump.
- Height: 1.127 inches
- Outer Diameter: 1.188 inches
| 1941-1951 | G |
| 1941-1948 | U |
