Harley Shinko SR268 140/80 x 19 Rear Flat Track Tire Soft - Shinko 87-4751S
by Shinko
SKU 46-0078
$159.99
1599 ENTRIES 🎟️
$159.99 - $159.99
$159.99
1599 ENTRIES 🎟️
Shinko SR268 rear flat track tires are designed and tested to perform at the highest level of the sport features a soft compound. *NOTE: Tube type construction with a H speed rating and a 71 load index. **WARNING: Newly fitted tires should not be subjected to sudden acceleration hard cornering maximum power or braking for at least 100 dry miles. Loss of control and serious injury or death may be a result in doing so. By waiting till the 100 mile break in the driver will become accustomed to the feel of the new tires or tire combination. You should check and adjust inflation pressure to recommended levels after tires cool for at least 3 hours following run in. **NOTE: D.O.T. approved. ***Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. Universal fit for most Harley applications.
Shinko #: 87-4751S
0 Rear
