Shifter Shaft Cam Lock Screw - Eastern A-34050-36 - OEM 34050-36
by Eastern
SKU 17-0132
Eastern #: A-34050-36 · OEM #: 34050-36, 2244-36A
Transmission shifter shaft cam lock screw measures 1/4 inch-24 and is for use with 3 and 4-Speed transmissions.
When rebuilding your 4-speed transmission be sure to replace your worn out components with our genuine V-Twin Mfg. replica parts. Such as our Shifter Shaft Cam Lockkscrew. This is a replica replacement that is for use in 1941-78 3 and 4-speed transmissions.
1941-1978 FL
1971-1978 FX
