Servi-Car and Solo Gas & Oil Tank Set - V-Twin 38-0576
Gas & oil tank set features provisions for shut off rod assembly.
Set accepts 2 3 and cast lite dash fuel shut off rod and 1947-1973 type late model shift gate. Order emblems emblem mounts and stainless trim separately. 45 tank set space as required to allow fitting dash base and cover use 5/16 inch inner diameter washer between tanks and frame.
- Gas Capacity: 3.4 Gallon
- Oil Capacity: 3.5 Quart
| 1947-1957 | G |
| 1947-1952 | W |
