S&S Stock Bore Engine Crankcase Set - S&S Cycle 31-0008
SKU 10-0029
Original price $1,879.99 - Original price $1,879.99
$1,879.99
$1,879.99 - $1,879.99
$1,879.99
S&S Cycle #: 31-0008
Crankcase set for Panhead engines comes ready to assemble.
S&S Crankcase Sets are shipped set up with Timken left side bearing and race assembly seal and seal spacer oil pump drive bushing needle bearing and pinion race for right side is pressed in and line honed ready to assemble. Also included are cylinder studs nickel plated case bolts crankcase fittings and a timing and magnetic drain plug. Engine crankcase features stock bore and accepts flywheels up to 8½ inch diameter. Manufacturer's Statement of Origin is supplied.
  • Order oil pump required for assembly
1948-1964 FL
