S&S Engine 6° Taper Sprocket Shaft - S&S Cycle 33-2004
SKU 10-0455
$169.99
$169.99 - $169.99
$169.99
S&S Cycle #: 33-2004
Shaft is machined and hardened to factory specifications. Includes nut and key. Shaft is designed to fit late model type flywheels with a 6° taper.
For use in S&S SE or SL flywheels only.
  • Suggested to use with Replica 3.968inch Stroke Flywheel Set.
0 Replacement
