Replica Swingarm Frame - V-Twin 51-1004
SKU 51-1004
Original price $1,439.99 - Original price $1,439.99
$1,439.99
$1,439.99 - $1,439.99
$1,439.99
Replica swingarm frame is an authentic reproduction of FLH style for 1965-1984.
Frame accepts Panhead or Shovelhead engine 4-speed transmission 12v battery and round swingarm for drum brake applications or a square swingarm for disc brakes. Details include forged parts as original in neck motor mounts front transmission mount plate top seat post yoke strut swingarm pivot mount and pin and footboard mount. Order shock studs separately. Rear drum brake models use 13-1/2 inch shocks. Tapered bearing cups are not included. *NOTE: Forged neck includes number box and neck lock tab. Frame includes oil tank bracket and rear seat post assembly. **NOTE: Seat post may require further reaming for proper fit. For this reason frames will not be accepted for return (RGA). *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. *NOTE: There are no serial numbers stamped on the replica frame. V-Twin MFG supplys a Bill of Sale only referencing the part number.
  • *NOTE: The size of the blank number pad on the right side of the neck measures 3/4inch x 3inch.
  • Suggested to order Shock Studs.
1965-1984 FL
