Harley Big Twin Replica Shovelhead Cylinder Head Set - V-Twin 11-0082
Replica Shovelhead cylinder head set for Big Twin models. Set is for stock lift cams only. Replica Shovelhead head sets feature rubber band type heads and are completely assembled with unleaded valve intake seats cast iron valve guides nitrated valves valve guide seals and stock type valve spring kit. Heads use long reach spark plugs and flat seals for the intake manifold. Heads fit all 1966-1984 Big Twins. Order stud set separately. Fits 1966-1984 Harley Big Twin, FX (Super Glide), and Shovelhead models.
- Recommended to use stud set.
| 1966-1984 | FL |
| 1971-1984 | FX |
