Harley Flathead Replica Seat Post Assembly Parkerized - V-Twin 49-1926 - OEM 51602-30
Replica parkerized seat post kits are assembled with heavy duty spring set installed. Seat post is 1.060 inch in diameter and uses the 14-3/4 inch spring rod. These seat posts are equipped with the heavy duty spring set installed! Order lever nut kit separately. Fits 1929-1973 Harley Flathead models.
OEM #: 51602-30, 3122-30
- Outer Diameter: 1.060 inches
- Length: 23-1/2 inches
- Suggested to use with #8874-2T Seat Post Rod Lock Nut and Lock Washer.
| 1933-1973 | G |
| 1930-1934 | VL |
| 1929-1952 | W |
