Harley Big Twin Replica Rear Fender Raw - V-Twin 50-0674 - OEM 59604-69B
SKU 50-0674
$299.99
2999 ENTRIES 🎟️
$299.99 - $299.99
$299.99
2999 ENTRIES 🎟️
Raw replica-style rear fender, a direct replacement for a dented, rusted, or missing stock fender. Fits 1958-1978 Harley Panhead and Shovelhead models.
OEM #: 59604-69B
2022 New Production replica fender with updated hinge and tail lamp cut-out features a raw finish.
Accepts early 1958-1972 type tail lamp and features mount holes for license plate bracket. We suggest pre fitting the fender prior to painting. Before priming or painting fit the fender body braces and mounting points in place. Fender rivets hinge and brackets will have to be tweaked for final fitment. All hinged fenders must be hand fitted at the hinge and pin area. Patience is required for proper installation! *NOTE: Assembled with updated hinge and pins for proper closure. Holes may need to be redrilled to mount correctly to frame hinge area may need to be reworked to close gap.
  • Width: 7-1/4 inches
1958-1978 FL
1958-1978 FLH
