Replica Raw Oil Tank - V-Twin 40-0489 - OEM 62504-38
SKU 40-0489
$189.99
1899 ENTRIES 🎟️
$189.99 - $189.99
$189.99
1899 ENTRIES 🎟️
OEM #: 62504-38, 3503-38
Replica raw oil tank features wrap around construction including seam-welded edges which show weld marks as on original tanks.
Tank is equipped with a screw in dipstick but does not have battery rod tabs. *NOTE: The battery compartment dimensions are 5 inch wide x 4-1/2 inch long x 7 inch tall.
  • Height Front: 7-1/8 inches
  • Height Rear: 6-1/2 inches
  • Depth: 7-3/4 inches
  • Depth of Battery: 5 inches
  • Width: 10 inches
  • Battery Width: 4-7/8 inches
  • Suggested to use #8115-1 #8114-1 or #9504-1 timing plugs.
1936-1940 EL
1941-1957 FL
1938-1947 UL
