Harley Big Twin Replica Raw Front Fender - Wyatt Gatling 72635 - OEM 59000-58G
SKU 50-0124
$139.99
1399 ENTRIES 🎟️
$139.99 - $139.99
$139.99
1399 ENTRIES 🎟️
Raw replica-style front fender, a direct replacement for a dented, rusted, or missing stock fender. Fits 1948-1984 Harley Touring, Panhead, and Shovelhead models.
Wyatt Gatling #: 72635 · OEM #: 59000-58G
Replica front fender has a raw finish with heavy gauge reinforced brackets riveted on.
Brackets are correct for 1958-1984 and will fit 1949-1984. Fender is for 41mm wide style glide fork assembly and 16 inch wheels. This fender is without trim holes for fender tip spears or bumper. Before priming or painting fit the fender body braces and mounting points in place. Fender rivets hinge and brackets will have to be tweaked for final fitment. Patience is required for proper installation! *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Width of Fender: 6-7/16 inches
  • Width of Brackets: 7-7/8 inches
1948-1984 FLH
