Replica Oil Pump Assembly - V-Twin 12-1951
SKU 12-1951
Original price $689.99 - Original price $689.99
$689.99
$689.99 - $689.99
$689.99
Replica oil pump assembly includes cast outer cover without rotator. Pump is fitted with the late type oil pump relief valve kit. Body is zinc plated.
Assembly will only work with 1941-1947 FL Knucklehead models. Cover has correct shape with external oil control for 1941-1949 models but does not use governor rotor. *NOTE: Lower right hand threaded hole is 1/4 inch x 20 thread.
1941-1947 EL
1941-1947 FL
