Harley Big Twin Replica Mechanical Rear Brake Shoe Set - V-Twin 23-1750 - OEM 41805-38
SKU 23-1750
$139.99
1399 ENTRIES 🎟️
$139.99 - $139.99
$139.99
1399 ENTRIES 🎟️
Drum brake shoe set, a direct replacement for worn, glazed, or undersized stock shoes that are costing you stopping power. Fits 1936-1957 Harley Flathead, Knucklehead, and Panhead models.
OEM #: 41805-38, 4038-38A
Replica rear mechanical brake shoe set is complete with linings installed and original cast construction. Shoe set is approximately 12-1/8 inch long x 1-9/16 inch wide. The brake pad is 1.50 inch wide.
Linings are riveted on and are pre-arched to fit onto stock or our Replica mechanical drums. Sold as a pair.
  • Thick Linings: 5.0mm
  • Width: 37.3mm
1936-1940 EL
1941-1957 FL
1937-1948 UL
